Originally Posted by cfg83
88CRX -
The reason I am curious about it is that it *claims* to separate the H2 from the 02. If the gizmo is only sending H2 into the air intake, this would remove the need to modify the 02 sensor, which I like,  . But, I wouldn't pump the 02 into the cabin of the car, that's for sure.
CarloSW2
To send only the hydrogen to the intake is not to say the O2 sensor needs no voltage output mods. We're talking different "Os", here. The sensor sees a change in oxygen level from any altered combustion...either higher or lower, thereby telling the ignition computer more ( or less) fuel needs to be pulsed by the injector signal to force this A/F ratio / signal voltage to return to its preset value.
You wouldn't like a flow of "clean" oxygen in your cockpit? 20% of the air in there is oxygen, anyway. This "boost" may bump the O2 level to 22%. 23%? Your heater or A/C ... if the windows are closed ... is going to mix this small amount to barely measurable levels. And you're constantly adding carbon dioxide ( some similar small amount) as you exhale, anyway. Is this bad? Nobody worries about exhaling this gas which doesn't support life. Nobody.
-whitevette
