Old 11-22-2014, 10:55 AM   #7 (permalink)
user removed
Ever spun a camshaft with a wrench Neil? With all the valve train except the timing chain connected.
The reciprocation of the piston mass and a portion of the conn rod, means you are accelerating and decelerating each of those masses 8 times per combustion stroke (2 revs of the crank). Exponentially greater losses than valve actuation losses.
regards
mech
