Old 11-22-2014, 02:00 PM   #17 (permalink)
cowmeat
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
When I got home from work a minute ago, I finally got out the floor jack and took a look under Turtle.
I sense some suspicious lack of aerodynamics concerning Turtle's lower shell!
Most of the aero panels are missing, and one of the rear panels got squashed pretty bad.
Also, no Fumoto valve, just the stock bolt. Everything else seems to be in pretty good shape otherwise for a car with over 200K
Hmmmmm . . . . . . . what to do about the panels!
And then it hit me! I had the perfect piece of aluminum to fabricate a front panel with! I have had this sign for years, it was attached to a piece of plywood, and after carefully removing it,
I now had a piece of aluminum that was already almost the perfect size for the panel!
ID:	16464   Click image for larger version
ID:	16465   Click image for larger version
ID:	16466   Click image for larger version
