Had you had an injected SV (from 2004 ?) I would have suggested to run it on a single cylinder with the deactivated cylinder forced at WOT to reduce pumping losses.
Even better, to Atkinson it by delaying intake cams two tooth (involved quite a lot ...).
But since it is not injected, it is much more hassle and expense ...
Using the Elite to work is not an option, is it ?
