Maths made Easy
Hi,
If you know the distance travelled, (you said you do this daily) and the amount of fuel used to travel that distance-it's simple division.
Or find the same size tyres as the factory used-they are available!
As the tyre revolutions per mile are less you WILL get better fuel economy, BUT you will loose take-off power (torque) due to the diameter of the tyres being larger! (In your case THIS IS NEGLIGIBLE if the engine is healthy)
