Old 11-22-2014, 04:47 PM   #1 (permalink)
cowmeat
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
Make your own Insight front aero panel!
Part #1 of 2
So I finally jacked Turtle up this afternoon, and found it is missing most of the aero panels from the front. There are supposed to be three small ones fastened together under the motor, and I have none. No worries!
I measured the opening and drew up a rough sketch of the area that needed to be covered. Then I headed out to the shed to see what material I might already have laying around that I could use.
I remembered I had an old aluminum-skinned sign glued to plywood in the shed, and I found that it was the perfect size!
I removed the rear panel support crossbar, and screwed a borate furring strip to it to support the panel, then replaced it.
Then I loosened the front clips from the bumper, and inserted a PT 1x6 decking board into the gap.
ID:	16468   Click image for larger version
ID:	16469   Click image for larger version
ID:	16470   Click image for larger version
ID:	16471   Click image for larger version
The Following User Says Thank You to cowmeat For This Useful Post:
Ecky (11-22-2014)
