Old 11-23-2014, 02:29 PM   #3 (permalink)
PaulB2
Thanks for those links. I will see about the upper part ("sail panel") next, but I think I won't have much at the sides because it would interfere with access to the ramboxes.
Now that I've gone the cheap route and figured out the sticking points, I may re-do it a bit nicer. Also may play with raising the front to get a bit of taper in the shape, although I can't do much with the tailgate of course. Might even try tailgate down with a sheet of plywood extending back and tilted up at front (and down at back).
The real problem is that, being retired, I don't drive much and this is the least-driven vehicle.
