Old 11-24-2014, 04:39 AM   #4 (permalink)
freebeard
Before you go to the sail panel, try adding a partition wall under the half-tonneau. It should help.
Might even try tailgate down with a sheet of plywood extending back and tilted up at front (and down at back).
If your talking about from the top of the bed to the end of the tailgate, the angle is too steep. It shouldn't exceed 12°, so not 45°.
...another way to get a smoother surface...
A vinyl wrap? Plastidip S?
