Old 11-24-2014, 12:37 PM   #21 (permalink)
RustyLugNut
Never give up. Never surrender.
Originally Posted by Hypermiler1995 View Post
I surrender!
If you know what you have, you should be firm in your belief - belief based on evidence. Continue forward to collect more evidence.
Just go ahead and build your devices and take your steps. Be as open minded as you can and continue to learn as you gain experience. That experience will allow you to filter out the dross that collects around provocative subjects such as HHO.
The important thing is to understand the skepticism toward HHO is well warranted. Starting a thread in the Unicorn Corral is not an issue if you understand this standing can be reversed and the topic/thread can be moved out of the Corral if you can provide substantial evidence that meets or exceeds the Sagan Test.
The bottom line is the need to build, test and document to a higher degree than the pie tin and Coraplast crowd. You will come under scrutiny that is greater than the norm on this forum. You must have a much thicker skin than the rest. And that is as it should be.
If you need any help on your build, go ahead and disclose on a build thread and I can provide help on the matter both theoretical, practical and with hardware.
Most of the reasonable ridicule will come from people who are good contributors on this forum. If you test well, you can sway them. The rest - don't worry about.
The Following User Says Thank You to RustyLugNut For This Useful Post:
Hypermiler1995 (11-24-2014)
