The pie tin and coraplast crowd at least try to follow the teachings of aerodynamics, awell established subdiscipline of fluid mechanics.
The HHO crowd are a bunch of pseudoscience following perpetual motion machine builders.
You even made note of the fact that the complexity of my posts were the reason topics like this reside in the Corral. And that is fine by me. Why don't you debunk my numerous posts that a small amount of hydrogen and oxygen can affect the combustion profile through various thermochemical pathways? That is a well established discipline of chemistry.
I do not think the OP or Hypermiler pretend the addition HHO will allow us perpetual motion. You and others have put those words into this thread. Bad on you. In a court of law, your arguments would be disallowed.
They and myself are simply saying " a percentage gain may be had under the right circumstances - let us investigate".
If you want to add to the discussion - both pro and con - feel free. But do not drag the thread into the drivel that you suppose the Corral is filled with.
"Be kind to Unicorns". It's a simple concept to let them live or die on their own accord. They are fragile beings. They don't need your butchery.
