Old 11-24-2014, 08:26 PM   #63 (permalink)
Nigel_S
Originally Posted by Madact View Post
+ 4" flex pipe (will have to check how much length a 4" flex *actually* adds...) + 1" flange fitting = 8"
Not sure how much you know about flex pipes but some advice if you don't know:
If you have the room then I suggest a 6" one, I fitted a 6" to mine and it's a nice length, gives decent flexibility and stretchability, the 4" work but they are a lot less flexible.
"would be flex tube with an interlock liner." - mine is an interlocked one in full stainless, far superior to the standard corrugated ones, the inside is essentially smooth and the correct diameter throughout - no need to worry about it affecting the results.
The Following User Says Thank You to Nigel_S For This Useful Post:
Madact (11-24-2014)
