Old 11-26-2014, 10:52 AM   #20 (permalink)
jkv357
Originally Posted by darcane View Post
Smaller drive sprocket? That will increase your RPMs at any given speed. Larger drive sprocket or smaller driven sprocket should lower RPMs.(SNIP)
He did say that, didn't he?
As darcane stated, if that's the case (smaller front/countershaft sprocket), it's not helping you get better MPG.
I have gone to a 1T larger front/countershaft sprocket, mostly for the 500 RPM drop it gave on the hwy and the smoother range it put the engine in at those speeds.
I would at least go back to a stock sprocket (15T) and maybe try a 16T - they aren't expensive.
