If your talking about from the top of the bed to the end of the tailgate, the angle is too steep.
Yes, of course - although it depends on where you start. I suppose you start as high as possible, so going back as 12 degrees will still be above the tailgate.
I probably won't go further, other than as you suggest, a vinyl wrap. A half-tonneau by itself is little trouble, but adding the rest kinda gets in the way of the function of a pickup truck. If I am spending that much time on the highway I will be driving my Passat. :-)
