Old 11-26-2014, 06:34 PM   #19 (permalink)
aerohead
unsure
Originally Posted by paintme205 View Post
Well I'm unsure of my results at this point. I did the extended boattail, underbelly tray finished and then an alternator delete.
Drove 200 miles at 75-80 MPG. Winds were 45-50 MPH, temperature 45 degrees and speed was 75-80.
I only managed 43 MPG.
With that in mind, I'm going to test the alternator delete to that effect first. If I reconnect it, and mileage isn't better, I'm going to look at the boat tail design with a true a-b-a test.
Could you give us a sense of the driving conditions under which you achieved your baseline mpg?
*Winds sound like last Sunday.All the 18-wheelers down here pulled off the interstate and parked 'til it blew out.The big-dogs never attempt to test (or race) if the winds are above 8-12-mph.Direction could totally kill your mpg if you had any headwind vector (80 mph + 50 mph = 130 mph airspeed!).
*The 45-degrees will increase rolling resistance and prolong the time and distance to get them up to whatever temp they're going to see.
*The 45-degrees will affect the warmup and equilibrium viscosity of the gear oil in the transaxle,increasing driveline losses.
*The 45-degrees might also have increased the air density compared to baseline,and drag varies directly with density.
If you're pulling that kind of mpg under those kinds of conditions I'd be thinking that your already in 60+ mpg territory under better conditions.I'm impressed!
