Did you try the lower grill block with and without the upper? My lower doesn't seem to help too much and I've been meaning to try an upper.
Here's my lower grill block. Similar to yours except I used plastic cut from the back casing of a cracked LCD I found in a dumpster. I've painted it black, but here's the original pink, which is easier to see.
