Old 11-27-2014, 05:18 PM   #8 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.26 mpg (US)
Wow. You are hard core. I'm too lazy to be that ambitious.
A study of intake air temperature vs fuel flow vs torque for a range of typical RPM's would be good. The torque should encompass the range from WOT right down to zero. This would be good data for warm air intakes.
I also would like to see real dyno data for camshaft timing. The data should include the full range of torque from zero to WOT for the RPM's tested.
A garden hose is useable in cold weather. You just need to store it indoors and start the water flow immediately after hooking it up.
