Old 11-28-2014, 07:27 PM   #308 (permalink)
The donkey CRX
The donkey CRX's Avatar
MULE VX - '92 Honda civic VX
90 day: 92.6 mpg (US)
White 94 VX "Show Car" - '94 Honda Civic VX VX
90 day: 79.92 mpg (US)
The Walrus - '02 Honda Insight base
Gen-1 Insights
90 day: 100.88 mpg (US)
Pics of adjustable air dam shutters
John, you are in luck, during the upgrade of the Red Mule 92 VX I had to remove the nose, so I took some pictures of the adjustable shutters. Since you said you are planning a sliding opening I will start with the "choke cable" that I used to open and close the shutters from inside the car.
Here is a picture of the cable. I got them from JEGS and they are about $9, the cheapest I could find. They are 72" long and this length has been working for every thing I have tried to control in the engine bay (WAI and shutters)
Here are some pictures of how I mounted the cable inside the car. They are under the gauges that show the water temp measured from the lower radiator hose.
There is a large HVAC vent in the top middle of the dash that when removed allows access to the bulkhead into the engine bay. Sorry I did not take a picture of this. I drilled several 1" holes thru the bulkhead into the engine bay to route the cable to the shutters. I will try and get a picture of this tomorrow.
More to come
The Following 6 Users Say Thank You to The donkey CRX For This Useful Post:
Fat Charlie (12-01-2014), iveyjh (11-28-2014), j12piprius (11-28-2014), mikeyjd (01-07-2015), OG VX (11-29-2014), whatmaycome14 (08-19-2015)
