Old 11-29-2014, 12:17 AM   #310 (permalink)
j12piprius
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
undertray boxes
Originally Posted by ecoTex View Post
When we added the belly pan we wanted it to be lower than any under body part, totally flat from the tip of the air dam back to where it met the rear*diffuser*and level with the ground. This was done by putting all 4 wheels on 14 inch high plywood boxes
The donkey CRX, can you tell me where you got the 14" boxes, or how you made them? I was planning to use jack stands, but having the wheels on boxes would be much better and easier to work with. Would I be able to lift the car to the boxes with a floor jack? Thanks much for your helpfulness.
