Old 11-29-2014, 10:32 PM   #46 (permalink)
freebeard
I wouldn't use plywood anywhere on the outside bottom of a car unless the edges are very well sealed, like soaked in epoxy 1/2" deep.
The Lang Racing article suggests Alumilite. Similar products are Polymetal and Grimco MaxMetal. 3mm Polymetal is described as stiff as 5/8" ply at 1/10th the weight. Having experimented with samples I believe it. It is also available in 6mm, and MaxMetal is available with thicker aluminum skins.
I doubt the ABS would be as stiff.
Edit: Here's an interesting article: http://www.speedhunters.com/2012/06/...-is-the-force/
There is a venturi that starts mid-vehicle and passes over the differential and exits through the rear deck lid. Air scoops in the rear doors dump through the rear bumper.
ECONORAM (12-02-2014)
