Old 11-30-2014, 10:36 PM   #1 (permalink)
ever_green
ever_green's Avatar
gueff - '19 Mercedes Benz A250 4MATIC AMG
90 day: 30.55 mpg (US)
Lean burn on a stock Subaru Impreza engine
So I have always wanted to experiment with lean burn ever since seeing how people here were mostly fond of honda civic ex or whichever model that does do lean burn. Unfortunately I do not drive a honda as I drive a Impreza instead. There was no lean burn available for such cars (and most other cars on the market). However I do have a bit of experience self tuning my car and recently by accessing the maf scaling tables I managed to 'trick' the ecu in running lean AFRs (16.7:1).
how i did it this was by changing the air intake estimates (in g/s) in 2.0 to 2.35 voltage range of MAF sensor. I just underestimated the intake at these ranges and so the ecu injected less fuel. However in order to avoid the closed loop feedback system to correct this outrageous fuel mixture I had to create an Open Loop window in 1800-2500 RPM area in cruising load ranges. This way the O2 sensor couldn't correct the lean mixture!
here is a video of lean cruise
the AFR is reported by the front wideband sensor. I have only experiment with 16.7 AFR at roughly ~44* of ignition advance. not sure if going any leaner would be beneficial or not. The injector pulsewidth is now lower by 9% at highway cruising compared to stock.
