Originally Posted by Baltothewolf
Oh nice, well i hope you get a decent mpg bump from it! I know in high load scenarios my insight pings and once in a while knocks while in L/B, so I would definitely listen for that when over ~75% engine load and in L/B.
yes pinging is from overly high ignition timing. most manufacturers like to inflate timing and run at the hottest 14.7:1 AFR. this is mostly for emission purposes. My AFR enriches above 55% to something like 14.4 AFR and timing gets retarded. no knock from data logs so far.
