Old 12-01-2014, 10:46 AM   #11 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by Chrysler kid View Post
Lean burn is only available in 5th gear for the hx.
Our hx is a 1.6 motor
coupe only
wheels are light weight enkei designed wheels
5 pin wideband oxygen sensor
no moonroof
power windows and power locks standard
California models primarily did not have lean burn as it produces higher emissions
only civic from 92-00 to have an egr valve
cylinder head is designed to spin inward air into the combustion chamber
exhaust valve springs have a harder spring ratrate
Cam is slightly more agressive than ex model
The most telling sign a car is a hx is power windowindows with no sunroof. All ex trim models came with a moon roof, and all base models came without power windows
As far as lean burn it is the computer relying the car to restrict fuel above a cetrain speed and throttle point
I must correct you on the gear, when I had my '97 HX I was able to get into L/B in 3/4/5th gear.
