Old 12-01-2014, 12:23 PM   #160 (permalink)
xavi
eco cam operation
For what I can tell, it engages easy under 20-25 LOD, but it disengages above 65-68 LOD... LOD should be the primary factor...
So what I do?
After putting the gear I wanted for that road speed, I speed up a little so I can lift the throttle enough to engage it, and then I can acelarate some more with eco cam on... but even in Eco-cam operation, it can show from 2 to 8-9 lt/100km...
So, within eco cam operation, other variables still change the instant consumption a lot such as rpm, LOD, speed, etc...
Negative thing I see is when taking the foor off throttle, it desengages, and when I am obligated to take it off due to traffic, I then find dificult to engage it again...
Example, I activate it when on flat so I can overtake a small hill... So I activate it keeping it at low LOD, but since I now go on 50 LOD it stays on...
Some traffic make me loose the throttle for a second or 2, then it disengages, but with the 50 LOD I need to go uphill I cannot engage it again...
2 chance here: I speed a lot to loose throttle again and activate eco cam, or I stay with the 50 LOD without eco-cam...
If the hill is big I make 1st option, if is small I do the 2nd option...
With the led we start to "feel" when it goes out of eco-cam, cause it makes a small bump every time the led turns off if we are still acelarating...
The Following User Says Thank You to xavi For This Useful Post:
MetroMPG (12-03-2014)
