Old 12-01-2014, 01:06 PM   #11 (permalink)
serialk11r
That chart is if you hold the airflow constant and change the fuel. However at constant power and speed, leaner requires a bigger throttle opening like Ecky said, and you'll get gains well past 16:1. Honda's lean burn engines ran 22:1 despite poor combustion, because it's more efficient to pump a lot of extra air and not have the gasoline burn completely than to restrict the engine and run stoichiometric with low MAP.
The Following User Says Thank You to serialk11r For This Useful Post:
LeanMeanDSM (06-05-2016)
