Steve, you are right. Now I'm even more disappointed. 16x4=64. Bummer. What's even better (or worse, depending on how you look at it) is the fact I discovered the OEM 20" wheels weigh 36# each if painted (like mine), 37# each if chrome plated. So, even less weight change per wheel. I still may go with some 17s like tvago if I can find a set for less than $110/wheel that don't look like ragged crash survivors...
