Originally Posted by pletby
Right on! Thanks that helps me out. I was just putting up with the display going dead multiple times a trip. Adjusted and tested. Happy dance!
You're quite welcome! I'm glad it helps.
Originally Posted by RPM
I may be late but can't you just use a front fog light button? It would look 100% OEM, factory quality.
Do you mean the rear window defogger? I like the kill switch on the shifter,
but the defogger button would be convenient to use as a starter button instead.
