Originally Posted by homeworkhome53
It makes sense, except gas is stored in tanks set below the frost line. Below the frost line the ground stays the same temperature the year around... Hence, no temperature change and no desnsity advantage....homeworkhome53
This is true. A local news station tested this "myth". They found a negligable difference in the temperature of the gas coming out of the nozzle between early morning, afternoon and evening.
