Old 12-02-2014, 09:20 AM   #10 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Originally Posted by ever_green View Post
With an automatic it is hurtful to transmission to switch from neutral to drive when car is moving.
Says who?
Unless the transmission shifting logic is poorly engineered and makes a sizeable clunk/jarring when doing so, there is no harm in going from neutral to drive. The Matrix is smooth as glass shifting to drive, even at freeway speeds. The feeling is similar to making a routine 3-4 shift, so I highly doubt the effect on the transmission is much different.
