Old 12-02-2014, 09:51 PM   #9 (permalink)
Fourbtgait
Thank you aerohead and freebeard.
Yes, I figured my question was on the edge of the black arts.
If I were to buold, it would be along the lines of the basecamp.
Ease of a cargo trailer is a factor, though curious of the factor of frontal wall 6' wide 1'6" tall sticking up above the tow vehicle.
I have given thought if I went with total 6' height, to cut/weld a lift top to increase inside height.
I do know from several conversations with people that the Chalet/Aliner trailers typically only drop mileage 2 mpg. Due to folded height way below the top of most tow vehicles though just under 7' in width. Even used ate pricey.
The Following User Says Thank You to Fourbtgait For This Useful Post:
aerohead (12-03-2014)
