Old 12-03-2014, 12:40 AM   #2 (permalink)
E-money
Here is the final list
Cooling:
74171-SP0-000 Radiator Mount Bracket
(2) 74172-SR3-000 Radiator Cushion Lower
74173-SJ4-000 Radiator Cushion Upper
19305-PT0-000 Thermostat Mounting Rubber
(4) 90635-PT0-802 Oil Pipe Clips
91314-634-000 Water Pipe O-Ring
Exhaust:
18120-P2A-000 Exhaust Manifold Cover
18115-P2A-000 Flange Gasket
(2) 18020-S01-A20 Front Exhaust Pipe Insulator B
53692-S04-000 Power Steering Heat Baffle Plate
(2) 18251-SR3-A22 Flex Joint Bolt B
(3) 18176-PM3-300 Exhaust Studs
(2) 18229-SNE-A01 Exhaust Pipe Gasket
18212-SF4-000 Exhaust Pipe Gasket
90451-P13-000 Special Washer for mounting exhaust
Brake:
(2) 42324-SB2-020 Hub Washer
(2) 43171-S04-003 Brake Shoe Return Spring A
(2) 43172-S04-003 Brake Shoe Return Spring B
(2) 43375-SA0-003 U-Clip
47360-SB2-000 Equalizer
47365-538-000 Pin Equalizer
47572-ST0-000 Wire Guide Base
47522-594-000 Parking Brake Adjusting Nut
43377-SH5-003 Left Adjuster Spring
43367-SH5-003 Right Adjuster Spring
47537-671-670 Parking Brake Rod Spring
Bolts:
(2) 95701-0802008
(2) 95701-06020-08
(4) 93403-08016-08 (8X16)
(12) 93405-06012-08 (6x12)
95701-06012-08
(4) 93402-08020-08 (8x20)
(2) 93403-08020-08 (8x20)
93892-04012-08
Nuts:
(14) 90115-SL5-A00
(3) 90212-SA5-003
(2)90115-659-003
Misc. Parts:
25610-P4R-A01 ATF Dipstick
91306-MG3-000
91307-PN3-000
(4) 91641-SM4-003 Screw Grommet (4mm)
90107-SM4-003 Hood Seal Clip
90201-SK7-000 Hex Cap nut (10mm) Wiper nut cap
