Old 12-03-2014, 09:41 AM   #634 (permalink)
basjoos
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
That's just what I need. Scrape the underside on the road and start a bush fire.
Starting to cogitate a few ideas on how to do this. Thinking hinged at bottom front of existing boattail. Metal bar frame skinned with coroplast for the underside. Frame will be positioned about a foot below the existing boattail at the back end to produce the reduced departure angle and will extend about a foot beyond the existing boattail. Two compression springs at back end to keep frame in down position when not in contact with road. Possibly small wheels under frame at back (wait to see where the coroplast shows road rash). Lower sides made of aluminum sheet with hinged seam (piano hinge)running length of boattail to maintain rigid shape in wind yet fold out when frame contacts road. Hinged aluminum bars to attach back of frame to back of boattail. Don't want to go with fabric sides to the boattail extension as that would likely flutter in the wind unless kept tensioned just right. Any thoughts? It would be illuminating to do a CFD image of the aerocivic with a 10 degree departure angle to see what the flow improvement would be.
aerocivic.com
The Following 2 Users Say Thank You to basjoos For This Useful Post:
aerohead (12-03-2014), BamZipPow (12-03-2014)
