Old 12-04-2014, 08:24 AM   #6953 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Here's what Greg Fordyce had to say:
The way I understand it, amps gives you torque and voltage gives you rpm. 500 amps through a motor will give the same torque at 12 volts as it will at 120 volts but the rpm will be 10x higher at 120 volts. So if you want ~500 amps through the motor at 3000 rpm then you need to double pack voltage. Or if this is not possible shift to a higher gear so motor rpms go down and allow more torque (amps) through motor.
So your choices are more batteries or a gearbox.
kits and boards
The Following 3 Users Say Thank You to MPaulHolmes For This Useful Post:
mpgmike (01-24-2022), thingstodo (12-06-2014)
