Thread: 600 mile tank!
Old 12-04-2014, 01:13 PM   #12 (permalink)
accord_minded
Is this thing on?
accord_minded's Avatar
The Wilbert - '04 Honda Accord EX
90 day: 37.54 mpg (US)
Tires
Originally Posted by kafer65 View Post
Fixed my previous post. It looked wierd when I reread it. What tires are you using? Is the ride ok or firm with the pressures you're using? One difference I noticed was I'm running 51 psi all around. Its a bit too firm but 49 was pretty good so I may go back to that. That works surprisingly well with the stock Yokos. I doubt it would be this comfortable with the Michelins I've used in the past.
I'm using the tiresthat came with the car...can't remember the brand off-hand (michelin or continental, I think). I saw no noticeable ride difference between the recommended 32/30 PSI and the sidewall maximum of 44 (which is what I have them set at now).
