Old 12-05-2014, 02:05 AM   #4 (permalink)
j12piprius
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
reversing the connections
It occurs to me that the positive injector wire at 30, going through the led light (or coil) then to ground, would turn the injectors back on. I'm going to avoid that by turning them around, running a positive wire through the led to 87, for when the relay is on, the injector positive to 87a for when the relay is off, and run the ground through 30 in reverse.
