Old 12-05-2014, 08:00 PM   #13 (permalink)
redneck
You will probably need to pull the starter again and inspect the ring gear for worn or missing teeth. When a engine is turned off, the engine will come to rest in only one of a few different locations around the flywheel. In other words, it may come to rest in that particular worn area of the ring gear more frequently.
Unfortunately, you will have to do some more investigating.
