The water pump does not produce significant pressure, the pressure in your cooling system comes from the expansion at the coolant heats up. The thermostat opens according to temperature, not pressure. A small capsule inside expands as heated, it is used against the spring that holds the thermostat closed. You can put a thermostat in a pan of water and heat it on your stove and watch it open.
You will get better mileage with a thermostat operating at the correct temperture than none at all. Even if air flow through the radiator was perfectly controlled, you would still have a longer warm up time
