Old 12-09-2014, 12:42 AM   #13 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by Sjoegerd View Post
I don't monitor the temperature. There is no temperature gauge in my 106. I have one of the most basic types. I am still thinking of and cheap way to monitor the temperature.
Mine is also the most basic version, I think only the P106 with 1.6 liter engine had a real engine temp gauge.
I am using the ScanGauge, but any OBD tool would have one. I see that you have a much older P106, so it may not be compatible with OBD, in which case:
  • If your engine has a coolant temperature gauge, then you can try to hack into the signal,
  • If it doesn't, you will have to add one yourself.
