Originally Posted by slownugly
i will install a volt meter to monitor either the o2 or injector pulse width average. It will look like it has a clock but it will actually tell me if its in lean burn.
ill also be adding a vaccum gauge and possibly a wideband air fuel gauge via gauge pods on the pillar.
How exactly did you install the voltmeter to monitor the 02 or injector width exactly??
What do you mean by ..."via gauge pods on the pillar?"
What are gauge pods, and what is the pillar you are referring to??
thanks.
