Originally Posted by P-hack
Yah, I'm not gonna mess with thousands of dollars for matlab, so I couldn't really see what you are getting at.
so 370v rms is suspiciously like (213 line to line) to (213 line to line) with 120 degrees separation. Still at a loss how you combine the two (three? four?) though (easy as an abstract equation, not sure how to in the real world). If you could then you could just keep repeating the process indefinitely. Ah well, good luck
I'm guessing you could do the same on LTSpice, haven't tried it tough.
Ill try to run a simulation using arduino and see where it goes.
