Old 12-09-2014, 03:59 PM   #1411 (permalink)
cts_casemod
Originally Posted by P-hack View Post
one thing that does occur to me, in lieu of a boost converter (and maybe this is what is in your matlab) is to repeatedly reverse the polarity of the battery pack itself via full bridge a-la square wave when feeding the inverter bus. Extra losses but 1/2 the batteries for a given bus voltage.
That would reassemble a line voltage doubler (I use them to operate 3ph equipment from a single phase supply).
And you don't need a full bridge, just two diodes on one phase with neutral being the center point and each diode charging a series capacitor.
I posted a improved version of that on #1407, along with the capacitor ripple waveform. Just remember that using diodes its not possible to regenerate back to the source (Battery)
Using the circuit on #1407 one could technically triple the output as well. Just add another capacitor/diode/IGBT
