Old 12-09-2014, 04:33 PM   #19 (permalink)
aerohead
axle width/deck height (leveling)/wheel diameter
I wanted to mention that the smaller trailer has a C-Channel axle,with stub-axle hubs captured by clamps.
Narrowing the axle would be straight forward if you chose to do that.
The frame members would have to be re-drilled for the new width,depending upon how much you shrunk the dimensions.
It would allow some flexibility with respect to the axle location.
I suppose that the receiver tow bar could be customized for a proper vertical ball position to keep the deck level.
The 12" wheels should have a rolling resistance advantage over the 8".If you can get the 14"s on there,it would really slow down the wheel bearings.
