Old 12-10-2014, 03:32 PM   #1416 (permalink)
e*clipse
Permanent Apprentice
It is true that running at a higher switching frequency allows you to reduce the inductor size.
Some years ago, I made a 1kW boost converter for a lithium battery charger. At the time, Infineon made an excellent control IC that was made specifically for a MPPT, high power factor, high efficiency boost converter. At the time I used a SiC diode, but SiC Mosfets weren't available.
They had excellent app notes regarding inductor sizing and the frequency relationship.
The DS pic would be quite capable of doing this. I don't see why an ARM or ST controller is necessarily better.
It may be possible to use a stand-alone controller with simple controls that could be administered by the main motor controller.
- E*clipse
The Following User Says Thank You to e*clipse For This Useful Post:
MPaulHolmes (12-10-2014)
