Old 12-10-2014, 11:22 PM   #6 (permalink)
evric
Gen2 Prius - '08 Toyota Prius
90 day: 98.01 mpg (US)
The Plugin Supply (10KWh) kit does all that for me. The front box connects to the OBD2 port under the steering wheel and tricks the car computer into thinking the battery is fully charged so makes maximum use of the battery. Also the front box has a switch that, when pressed, disables the petrol engine. This can only be used on the flat and around 60km/hr and under. Checkout the Plugin Supply website.
