Old 12-11-2014, 02:07 AM   #3 (permalink)
Frank Lee
I think the best way is to find a BSFC chart for your engine and note the sweet spot.
Failing that, I've been using a 1000-1200 ft/mn piston speed theory that postulates best or near best efficiency is found in that rpm range. I am still not sure about the validity of it but I've run the numbers on many vehicles and even if it isn't perfect it isn't going to be too far off.
The Following 4 Users Say Thank You to Frank Lee For This Useful Post:
Daox (12-11-2014), IamIan (12-11-2014), mikeyjd (12-31-2014), UltArc (12-13-2014)
