I want the toggle switch connected to the servo will then lift the fuse in and out of the fuse slot...disableing and ableing the vehicle.
Why do this by mechanical means when all you have to do is disconnect it electrically? I mean it would be really cool to do that way but you won't see it happen anyway. Just seems like a huge hassle to do it mechanically.
A remote engine start kit would do the same thing just hook it to the ecu power wire instead of the ignition wire.
