Thread: Floor Heat Pad?
Old 12-11-2014, 11:42 PM   #6 (permalink)
Frank Lee
Agreed that +50F is not cold. -50 on the other hand...
Pad on the floor would waste too much energy heating concrete. If you could prop it up so it's plastered to the bottom of the car- like set it on a piece of foil-faced foam board on legs- that might work. Or use a coolant heater. Or a lamp. Or forget it.
