Old 12-12-2014, 03:32 AM   #2 (permalink)
redpoint5
90 day: 38.47 mpg (US)
Here is the 1998 Dodge Ram I picked up at state auction. I asked an ODOT secretary if I could get the maintenance records on the truck and she sent me a phonebook sized package listing every service it had. I took ownership in 2006. The odometer doesn't work, so I don't know how many miles are on the truck. Likely close to 330,000 miles. Besides the broken odometer, the speedometer, cruise, AC, and gear indicator doesn't work. The headliner is falling down and to steer straight requires a back and forth motion between 11 and 1 o'clock positions.
I think the yellow DOT paint is original.
Date Service Performed Milage
7/14/1998 Bed liner 289
12/11/1998 V-Belt
5/12/1999 Annual Inspection 39,690
11/13/1999 3000mi Service 54,379
12/18/1999 3000mi Service 61,984
1/22/2000 3000mi Service 67,312
2/26/2000 3000mi Service 72,885
3/11/2000 3000mi Service 76,195
3/28/2000 3000mi Service 80,875
5/4/2000 Annual Inspection 84,104
5/13/2000 3000mi Service 84,503
5/19/2000 Check Transmission 84,760
5/24/2000 Check Transmission 84,760
6/14/2000 Check Lights 85,337
6/27/2000 Replace Mirror 85,337
7/14/2000 3000mi Service 90,381
7/18/2000 Check Transfer Case 90,381
7/18/2000 Install Steps 90,381
9/9/2000 3000mi Service 96,194
10/13/2000 3000mi Service 98,654
12/12/2000 3000mi Service 105,863
1/10/2001 Check Engine Knock 108,027
1/12/2001 Replace Engine-Rebuilt 108,027
1/30/2001 Replace Heater Hose 108,027
2/23/2001 Check Pulling Brakes 110,750
3/2/2001 3000mi Service 113,544
3/19/2001 Annual Inspection 112,882
3/28/2001 Check Brakes 117,312
4/8/2001 3000mi Service 118,574
4/22/2001 3000mi Service 80,451
6/1/2001 3000mi Service 121,397
7/22/2001 3000mi Service 124,163
10/28/2001 3000mi Service 128,619
12/11/2001 3000mi Service 134,262
1/20/2002 3000mi Service 102,636
2/5/2002 Replace Starter and Relay 143,168
2/14/2002 Check Front Brake Noise 144,727
2/28/2002 Mainenance 147,924
3/4/2002 Semi-Annual Inspection 147,924
3/5/2002 Check Brakes Pulling Left 147,957
3/6/2002 Check Radiator Leak-Split in Core 148,798
3/19/2002 Replace Radiator 148,798
3/19/2002 Change Rear Diff Oil 148,798
3/19/2002 Replace Rear Brake Pads 148,798
3/19/2002 Replace Front Brake Pads 148,798
3/19/2002 Replace Right Front Wheel Bearings 148,798
3/19/2002 Replace Horn 148,798
3/19/2002 Replace Transfer Case Output Seal 148,798
3/19/2002 Replace Transfer Case Shift Seal 148,798
3/19/2002 Oil and Lube 148,798
3/19/2002 Replace Calipers 148,798
3/19/2002 Replace Steering Stabilizer 148,798
3/19/2002 Replace Horn Switch 148,798
3/19/2002 Replace Drive Side Air Bag 148,798
3/19/2002 Turn Drums 148,798
3/19/2002 Turn Rotors 148,798
3/24/2002 3000mi Service 140,251
3/26/2002 3000mi Service 150,626
10/9/2002 Replace Front Brake Pads 159,940
12/26/2002 Replace Door Passenger Door Switch 165,632
4/7/2003 Replace Headlight Switch 190,978
12/2/2003 Replace Blower Switch 205,513
1/14/2004 Replace Calipers 219,000
1/22/2004 Replace Headlights 219,000
3/1/2004 Adjust Valves 221,834
3/16/2004 Replace Belt 222,297
6/1/2004 Replace Front Brake Pads 231,709
6/1/2004 Repack Front Wheel Bearings 231,709
7/7/2004 Oil Pan Drain Seal and Plug 234,243
7/8/2004 Replace Tranny(47RE) and Torque Converter 233,331
7/8/2004 Replace Neutral Switch 233,331
7/8/2004 Replace Blower Switch 233,331
7/8/2004 Replace Backup Light Switch 233,331
7/8/2004 30000mi Service 234,296
7/14/2004 Check Brake Pull 234,243
9/8/2004 Upholster Drivers Seat 235,003
11/10/2004 Repair High Beam 239,548
12/15/2004 Replace Front Brake Pads 244,880
1/18/2005 Replace Inner Axle Seals
1/20/2005 Front Axle Work
3/9/2005 Check Brake Pull 256,011
3/21/2005 Repair Transfer Case Leak 256,011
4/8/2005 Replace Alternator / Belt 262,959
6/10/2005 Replace Rear Brake Pads 270,093
8/4/2005 Replace Highbeam Indicator 271,694
8/4/2005 Pressure Test Cooling System-Check OK 271,694
8/4/2005 Replace Track Bar 271,694
8/16/2005 Replace Headlights 273,015
1/5/2006 Oil Change Amsoil 10w-40 purolator 275,000
4/1/2006 Air filter 276,000
6/24/2006 Transmission Fluid/Filter Change 278,275
9/15/2006 Fuel Filter 285,000
9/15/2006 Front Brake Calipers 285,000
10/3/2006 Tires (Bridestone AT Revo) $730 285,000
12/14/2006 Oil Change Amsoil 10w-40 purolator 286,000
1/8/2007 Thermostat 287,000
4/1/2010 Rear differentail oil - 80W-90 300,000
6/1/2012 Oil Change ?
4/1/2014 Oil Change ?
