Originally Posted by JRMichler
Or put in a vacuum gauge and practice DWL. If you run consistently at 12 to 15 In Hg vacuum or higher, a taller final drive ratio will help. If you are consistently less than 8 to 10 In Hg vacuum, your existing final drive ratio is good.
Thanks for the tip. I'll get a vacumm gauge and see what I come up with.
What DWL?
