Thread
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control
12-12-2014, 04:42 PM
1434
permalink
cts_casemod
Originally Posted by
e*clipse
That's why I really like those SOT-227 modules. They're much smaller than the "bricks" and they still use bolt-on busbars.
Regarding SiC diodes, my old spreadsheets (this was done about 10 years ago) indicate a forward voltage of 0.86V for a 1kW boost converter. I know parts have improved since then, for example I can't wait till this is available:
All-SiC and Si IGBT + SiC Rectifier CoPack from GeneSic Semiconductor
That Infineon IC that I used was truly amazing. It tracked the input current and adjusted the output so that the Power Factor was always near 1. The switching frequency I designed for was 100kHz, and I used a torroidal inductor.
In addition, Infineon also provided some good information for designing boost converters.
http://www.infineon.com/dgdl/Product...12b427caa43ccf
http://powerelectronics.com/site-fil...g/410pet21.pdf
ICE2xXXX ... - Datasheet Search Engine Download
- E*clipse
Thats quite good.
High frequency PFC diodes I had have a drop of at least 1.1V unloaded.
I use this converter in my 1.5KW modules. Current is set via a shunt resistor.
MC34262-D
The Following User Says Thank You to cts_casemod For This Useful Post:
e*clipse
(12-12-2014)
cts_casemod
View Public Profile
Send a private message to cts_casemod
Find More Posts by cts_casemod
