Originally Posted by P-hack
Yup, I'm experimenting with a 72mhz 100 pin STM32F103VCT6 (huebner code compatible) dev board. Hoping to integrate everything BMS/Charger/controller/instrumentation feed (maybe buck/boost), someday, for no good reason  So at least my experiments should be more port-able, someday. I doubt it will be timely though as there are far less challenging ways for me to get rolling.
Huebner setup is cool. I never got to past the toolchain configuration, tough. Are you using his code?
I proposed him to make a compatible setup with some stuff I was working in the past to incorporate charger and EVSE communication. Since he wasn't very receptive I decided to roll my own.
Have you had a look at the piccolo series from Texas?
